Einleitung
The inner cooking chamber may get dirtied or broken with use. This guide will show how to remove the inner chamber in order to properly replace it.
Was du brauchst
Remove the eight 22mm Phillips #1 screws from the grey lining.
Remove the grey liner.
Remove the four 11mm Phillips #1 screws holding from the guard and inner lining.
Remove small rectangular guard from bottom of liner
Remove the single 11mm Phillips #1 screw thats holding and inner lining in place.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
