Einleitung
This blender is a staple of a majority of common households. It consists of a motherboard and motor that allows the blender to work. For this repair guide, our main focus is to disassemble the motor from the rest of the blender.
Was du brauchst
Take the blender and place the top, cup, and blades aside
Flip over the base containing the motor of the blender
Use the Phillips Head Screwdriver to remove the 4 screws as pictured
Use an 11mm screwdriver to remove the screw from the fan blade
Remove the fan blade
Use a 6.5mm wrench and extender to remove the 2 screws holding the top of the motor in place
Remove the 4 bolts connecting the motor to the blender wall using a socket wrench
Flip the blender back over to the original position and remove the metal disk located at the top of the blender using pliers
