Zum Hauptinhalt wechseln
Outdoor Faucet Head Replacement
Was du brauchst
  1. Outdoor Faucet Head Replacement, Outdoor Faucet Head: Schritt 1, Bild 1 von 1
    • Check the location of the water leakage, and turn off the water to that area.
    • Drain the water in the pipeline after it is determined, so as to avoid a large amount of water flowing out during the repair process.
  2. Outdoor Faucet Head Replacement: Schritt 2, Bild 1 von 1
    • Use a wrench to remove the leaking faucet by turning it counter-clockwise.
    • Be careful not to damage the water pipe.
  3. Outdoor Faucet Head Replacement: Schritt 3, Bild 1 von 2 Outdoor Faucet Head Replacement: Schritt 3, Bild 2 von 2
    • Use PFTE tape to wrap the faucet mouth.
    • The purpose of this step is to prevent the faucet from still leaking after installation.
  4. Outdoor Faucet Head Replacement: Schritt 4, Bild 1 von 2 Outdoor Faucet Head Replacement: Schritt 4, Bild 2 von 2
    • Install the replaced new faucet and confirm whether it is tightened.
  5. Outdoor Faucet Head Replacement: Schritt 5, Bild 1 von 1
    • Turn on the faucet and monitor whether the faucet is leaking. If not, the repair is over.
Abschluss
There are no sharp objects used in the whole process, but you need to be careful that there may be places where the water pipes may be easily scratched.
Zelong jiao
268 Reputation
1 Anleitung geschrieben
York University, Team F-29, Woodhouse Fall 2021 Mitglied von York University, Team F-29, Woodhouse Fall 2021
YORK-WOODHOUSE-F21SFG29
1 Mitglied
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 25
Insgesamt: 970
