Zum Hauptinhalt wechseln
Ovation Acoustic Guitar String Replacement
Was du brauchst
  1. Ovation Acoustic Guitar String Replacement, Guitar String: Schritt 1, Bild 1 von 1
    • Place the guitar neck where you can easily identify the broken string.
  2. Ovation Acoustic Guitar String Replacement: Schritt 2, Bild 1 von 2 Ovation Acoustic Guitar String Replacement: Schritt 2, Bild 2 von 2
    • Place the guitar neck on an elevated surface (ex. bundle towels, pillow, etc.). Remove the string with a string winder until it is loose enough to pull out by hand.
  3. Ovation Acoustic Guitar String Replacement: Schritt 3, Bild 1 von 1
    • Take the string out carefully and begin to pull the string out through the bridge which is at the lower end of the guitar.
  4. Ovation Acoustic Guitar String Replacement: Schritt 4, Bild 1 von 2 Ovation Acoustic Guitar String Replacement: Schritt 4, Bild 2 von 2
    • Once the string is removed, wipe down the guitar neck to prevent further oil buildup.
  5. Ovation Acoustic Guitar String Replacement: Schritt 5, Bild 1 von 1
    • Layout the new guitar strings from biggest to smallest.
  6. Ovation Acoustic Guitar String Replacement: Schritt 6, Bild 1 von 3 Ovation Acoustic Guitar String Replacement: Schritt 6, Bild 2 von 3 Ovation Acoustic Guitar String Replacement: Schritt 6, Bild 3 von 3
    • Pull the new string through the bridge until the stopper is flushed with the bridge.
  7. Ovation Acoustic Guitar String Replacement: Schritt 7, Bild 1 von 2 Ovation Acoustic Guitar String Replacement: Schritt 7, Bild 2 von 2
    • Position the skinny side of the string into the tuning peg. Allow enough excess string ( about 3 inches) so when the string is tightened, it will not break from being too tight or break from being too loose.
  8. Ovation Acoustic Guitar String Replacement: Schritt 8, Bild 1 von 3 Ovation Acoustic Guitar String Replacement: Schritt 8, Bild 2 von 3 Ovation Acoustic Guitar String Replacement: Schritt 8, Bild 3 von 3
    • Loop the excess guitar string around the tuning peg and make sure the coil is being tuned downwards.
  9. Ovation Acoustic Guitar String Replacement: Schritt 9, Bild 1 von 2 Ovation Acoustic Guitar String Replacement: Schritt 9, Bild 2 von 2
    • Trim the excess string with pliers. Make sure it is cut as close to the tuning peg so it does not stick out.
Ziellinie
Rachel Galvan
169 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team S1-G6, Harris Fall 2021 Mitglied von CSU Los Angeles, Team S1-G6, Harris Fall 2021
CSULA-HARRIS-F21S1G6
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 21
Insgesamt: 881
