Was du brauchst
Using a 2.0 Flathead screwdriver, remove the 9.50 mm Phillips head screw under the sticker.
Using a 2.0 Flathead screwdriver, remove the two 18.76 mm Phillips head screws in the plate stand.
Using a 2.0 Flathead screwdriver, remove the 9.44 mm Phillips head screw on the edge opposite to the LCD screen.
Using the iFixit opening tool, pry off the two rubber stubs on the right side and the two rubber stubs on the left side of the bottom of the device.
Using a 2.0 Flathead screwdriver, remove the four 9.46 mm Phillips head screws that were under the rubber stubs.
Pry apart the two panels to separate them from each other.
Flip the device over so the LCD is facing up. Flip the front panel over on its side.
