Was du brauchst
Press a paper clip in the three places marked in red
Lift the keyboard and feel free to put some strength
Pull the white drawer in the direction of the arrow to unlock the connector
Disconnect the red circled connector
Pull the black drawer in the direction of the arrow to unlock the connector
Lift the flap that holds the connector circled in red
Remove the keyboard
To reassemble your device, follow the instructions in the reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
Ein Kommentar
When sourcing a replacement battery note which connector pin has the red wire. This is shown most clearly in the middle photo for step 12. Be careful, as similar batteries have the reverse polarity.
I bought a ten-pack of batteries for less than some suppliers were selling a single battery. EEMB CR2032-Molex51021-RP (CR2032-MX51021-RP). The connecting wires were longer than the original, but were easy to fit into the battery space.
Very many thanks for this great guide - it saved me a lot of unnecessary work.
