Was du brauchst
Press a paper clip in the three places marked in red
Lift the keyboard and feel free to put some strength
Pull the white drawer in the direction of the arrow to unlock the connector
Disconnect the red circled connector
Pull the black drawer in the direction of the arrow to unlock the connector
Lift the flap that holds the connector circled in red
Remove the keyboard
To reassemble your device, follow the instructions in reverse order.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
3 Kommentare
I wish to know whether it’s possible to pry off the key to clean off the contacts. (I spilled coffee on the keyboard).
Fortunately for me, the key was on the edge of the board (the down arrow key). It was stuck on.
I lifted the key up as much as I could and I cleaned it with Deoxit. That did the trick. My keyboard is now working.
Thanks for the steps!
Great instructions, but for my laptop, step 7 only indicated three of seven places (the other four are the top centre of the keyboard, and the three points symmetrical to the 3 you’ve indacted, on the right hand side of the keyboard).
