Zum Hauptinhalt wechseln
PDP Afterglow Fener Battery Replacement
Was du brauchst
  1. PDP Afterglow Fener Battery Replacement, Battery: Schritt 1, Bild 1 von 2 PDP Afterglow Fener Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
  2. PDP Afterglow Fener Battery Replacement: Schritt 2, Bild 1 von 2 PDP Afterglow Fener Battery Replacement: Schritt 2, Bild 2 von 2
    • This shows what your device looks like on the inside behind the part that you just removed from the headset.
    • In the red square is the connection between the battery and the headset.
    • Gently pull the wires that are connected to the white part in the red square.
    • Now that your battery is not connected to anything you can take it out of the headset.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Murat Terzi
210 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 Mitglied von UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G3
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Broke the headset while doing this “easy process” don’t listen to this method.
Daniel Sumida - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 7,395
