Zum Hauptinhalt wechseln
PDP Afterglow Fener LED Replacement
Was du brauchst
  1. PDP Afterglow Fener LED Replacement, LED: Schritt 1, Bild 1 von 3 PDP Afterglow Fener LED Replacement, LED: Schritt 1, Bild 2 von 3 PDP Afterglow Fener LED Replacement, LED: Schritt 1, Bild 3 von 3
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide here.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
    • This is a picture of what your headset looks like now that you have done the first two steps and have removed the part that you unscrewed.
  2. PDP Afterglow Fener LED Replacement: Schritt 2, Bild 1 von 2 PDP Afterglow Fener LED Replacement: Schritt 2, Bild 2 von 2
    • First remove the battery from the headset, for instructions on how to do this correctly go here
    • Now take your J000 screwdriver and unscrew the screws that have a red circle around them.
    • Now remove the circuit board from the headset and flip it to the other side to be able to see the light/LED.
  3. PDP Afterglow Fener LED Replacement: Schritt 3, Bild 1 von 3 PDP Afterglow Fener LED Replacement: Schritt 3, Bild 2 von 3 PDP Afterglow Fener LED Replacement: Schritt 3, Bild 3 von 3
    • Take your helping hand with alligator clips and put the printed circuit board on it.
    • This picture is a close up of the LED with the highlighted areas you need to unsoldered.
    • Now take your soldering iron and unsolder those four highlighted areas.
    • Your LED should come loose and you can now put on your new LED.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 Mitglied von UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 821
