Zum Hauptinhalt wechseln
PDP Afterglow Fener Speaker Replacement
Was du brauchst
  1. PDP Afterglow Fener Speaker Replacement, Speaker: Schritt 1, Bild 1 von 3 PDP Afterglow Fener Speaker Replacement, Speaker: Schritt 1, Bild 2 von 3 PDP Afterglow Fener Speaker Replacement, Speaker: Schritt 1, Bild 3 von 3
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide here.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
    • This is a picture of what your headset looks like now that you have done the first two steps.
    • Remove the wire connected in the red box by gently pulling it off.
  2. PDP Afterglow Fener Speaker Replacement: Schritt 2, Bild 1 von 3 PDP Afterglow Fener Speaker Replacement: Schritt 2, Bild 2 von 3 PDP Afterglow Fener Speaker Replacement: Schritt 2, Bild 3 von 3
    • Take your soldering iron and unsolder the wire from the speaker.
    • The red square is the left tip and the orange square is the right tip.
    • Before wiring your new speaker in, clean the left and right tips with your soldering iron.
Abschluss
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 Mitglied von UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 1,510
