Zum Hauptinhalt wechseln
PDP Afterglow Wired Xbox 360 Controller Button Replacement
Was du brauchst
  1. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: Schritt 1, Bild 1 von 2 PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: Schritt 1, Bild 2 von 2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
    Frag FixBot
    Kommentar hinzufügen
  2. PDP Afterglow Wired Xbox 360 Controller Button Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
    Frag FixBot
  3. PDP Afterglow Wired Xbox 360 Controller Button Replacement: Schritt 3, Bild 1 von 1
    • Remove the top cover from the bottom and place next to each other.
    Frag FixBot
  4. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Button: Schritt 4, Bild 1 von 1
    • Remove the rubber button covers from the A, B, X, and Y buttons.
    Frag FixBot
  5. PDP Afterglow Wired Xbox 360 Controller Button Replacement: Schritt 5, Bild 1 von 2 PDP Afterglow Wired Xbox 360 Controller Button Replacement: Schritt 5, Bild 2 von 2
    • Push up on the buttons from the front and pull them out from the back.
    Frag FixBot
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
IUPUI, Team 3-1, Harley Fall 2015 Mitglied von IUPUI, Team 3-1, Harley Fall 2015
IUPUI-HARLEY-F15S3G1
4 Mitglieder
5 Anleitungen geschrieben
4 Kommentare zur Anleitung
What about removing the Dpad? i really need help.
Elijah Douglas - Antwort Teilen
I’m sorry but, I have to say that the reassembly process is harder than simply ‘follow the instructions in reverse’; if you try and place the half with the buttons, the buttons fall out or end up misaligned ; and if you use the other half, the rubber covers and the tumblers will fall out.
Again, this guild comes off a little too simple, there’s more to it.
Christopher Mali-Martinez - Antwort Teilen
the circuit board comes off the other half. You can stack them very easily. You're simply incorrect.
Tyler Anderson - Antwort Teilen
No not really I agree with homeboy cause I just took mine apart to fix drifting and the one piece clip for RB and Lb doesn’t just fit in there right
David Drinkard - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 16
Letzte 30 Tage: 90
Insgesamt: 6,590
