Einleitung
Since replacing the cable requires the use of a soldering iron, there is a risk of burning yourself or damaging the controllers logic board.
Was du brauchst
Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
The cable connects to the logic board with a white connector. Above the right joystick, there are four solder pins labeled GND, VCC, DM, and DP.
Using your new cable, solder the white connector to the logic board. Be sure to have the cables facing towards the inside of the logic board.
5 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
where can I find a replacement cable to perform this precedure with?
yes!! i would like to know too.. i have been searching for long time for that cable
Android cable
Wayne -
