Zum Hauptinhalt wechseln
PDP Afterglow Wired Xbox 360 Controller Cable Replacement
Was du brauchst
  1. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: Schritt 1, Bild 1 von 2 PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: Schritt 1, Bild 2 von 2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
    Frag FixBot
    Kommentar hinzufügen
  2. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
    Frag FixBot
  3. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: Schritt 3, Bild 1 von 1
    • Remove the top cover from the bottom and place next to each other.
    Frag FixBot
  4. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: Schritt 4, Bild 1 von 2 PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: Schritt 4, Bild 2 von 2
    • Remove the logic board by lifting up on the logic board and pulling out.
    Frag FixBot
  5. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: Schritt 5, Bild 1 von 1
    • The cable connects to the logic board with a white connector. Above the right joystick, there are four solder pins labeled GND, VCC, DM, and DP.
    Frag FixBot
  6. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: Schritt 6, Bild 1 von 1
    • The soldering iron is very hot and can harm you or the device if used incorrectly.
    • Desolder the four pins.
    Frag FixBot
  7. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: Schritt 7, Bild 1 von 1
    • Using your new cable, solder the white connector to the logic board. Be sure to have the cables facing towards the inside of the logic board.
    Frag FixBot
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
IUPUI, Team 3-1, Harley Fall 2015 Mitglied von IUPUI, Team 3-1, Harley Fall 2015
IUPUI-HARLEY-F15S3G1
4 Mitglieder
5 Anleitungen geschrieben
4 Kommentare zur Anleitung
where can I find a replacement cable to perform this precedure with?
Aaron English - Antwort Teilen
yes!! i would like to know too.. i have been searching for long time for that cable
sokratis162 - Antwort Teilen
Android cable
Wayne - Antwort Teilen
U can use a old Android cable
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 69
Insgesamt: 8,518
