Zum Hauptinhalt wechseln
PDP Rematch Action Buttons Replacement
Was du brauchst
  1. PDP Rematch Action Buttons Replacement, Faceplate: Schritt 1, Bild 1 von 2 PDP Rematch Action Buttons Replacement, Faceplate: Schritt 1, Bild 2 von 2
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
    Frag FixBot
  2. PDP Rematch Action Buttons Replacement: Schritt 2, Bild 1 von 2 PDP Rematch Action Buttons Replacement: Schritt 2, Bild 2 von 2
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
    Frag FixBot
  3. PDP Rematch Action Buttons Replacement: Schritt 3, Bild 1 von 2 PDP Rematch Action Buttons Replacement: Schritt 3, Bild 2 von 2
    • Gently lift off the hard cover with your hand; it should not need much force.
    Frag FixBot
  4. PDP Rematch Action Buttons Replacement, Action Buttons: Schritt 4, Bild 1 von 1
    • Optional: Use a cotton pad or cotton swab with some alcohol to gently clean any debris.
    • These buttons are not connected to the device and will fall out, so be careful.
    Frag FixBot
  5. PDP Rematch Action Buttons Replacement: Schritt 5, Bild 1 von 3 PDP Rematch Action Buttons Replacement: Schritt 5, Bild 2 von 3 PDP Rematch Action Buttons Replacement: Schritt 5, Bild 3 von 3
    • Carefully remove the buttons from the device and set them aside.
    • From here, you can do a deeper clean, or replace them.
    • The clear plate will not sit right or click into place if the buttons are not aligned straight.
    Frag FixBot
Abschluss
Katie Barnes
85 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 57
Insgesamt: 814
