Zum Hauptinhalt wechseln
PDP Rematch Advanced Front Housing Shell Replacement
Was du brauchst
  1. PDP Rematch Advanced Front Housing Shell Replacement, Front Housing Shell: Schritt 1, Bild 1 von 3 PDP Rematch Advanced Front Housing Shell Replacement, Front Housing Shell: Schritt 1, Bild 2 von 3 PDP Rematch Advanced Front Housing Shell Replacement, Front Housing Shell: Schritt 1, Bild 3 von 3
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
    Frag FixBot
  2. PDP Rematch Advanced Front Housing Shell Replacement: Schritt 2, Bild 1 von 3 PDP Rematch Advanced Front Housing Shell Replacement: Schritt 2, Bild 2 von 3 PDP Rematch Advanced Front Housing Shell Replacement: Schritt 2, Bild 3 von 3
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
    Frag FixBot
  3. PDP Rematch Advanced Front Housing Shell Replacement: Schritt 3, Bild 1 von 3 PDP Rematch Advanced Front Housing Shell Replacement: Schritt 3, Bild 2 von 3 PDP Rematch Advanced Front Housing Shell Replacement: Schritt 3, Bild 3 von 3
    • Peel the rubber piece off the back of the face buttons.
    Frag FixBot
  4. PDP Rematch Advanced Front Housing Shell Replacement: Schritt 4, Bild 1 von 3 PDP Rematch Advanced Front Housing Shell Replacement: Schritt 4, Bild 2 von 3 PDP Rematch Advanced Front Housing Shell Replacement: Schritt 4, Bild 3 von 3
    • Push all the face buttons out from the front of the shell.
    Frag FixBot
  5. PDP Rematch Advanced Front Housing Shell Replacement: Schritt 5, Bild 1 von 3 PDP Rematch Advanced Front Housing Shell Replacement: Schritt 5, Bild 2 von 3 PDP Rematch Advanced Front Housing Shell Replacement: Schritt 5, Bild 3 von 3
    • Put two fingers behind the bumpers and push upwards to remove them.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Utah Tech University, Team 1-1, McMurrin Spring 2024 Mitglied von Utah Tech University, Team 1-1, McMurrin Spring 2024
UTAHTECH-MCMURRIN-S24S1G1
2 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 42
Insgesamt: 444
