Zum Hauptinhalt wechseln
PDP Rematch Advanced Trigger Springs Replacement
Was du brauchst
  1. PDP Rematch Advanced Trigger Springs Replacement, Trigger Springs: Schritt 1, Bild 1 von 2 PDP Rematch Advanced Trigger Springs Replacement, Trigger Springs: Schritt 1, Bild 2 von 2
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
    Frag FixBot
  2. PDP Rematch Advanced Trigger Springs Replacement: Schritt 2, Bild 1 von 3 PDP Rematch Advanced Trigger Springs Replacement: Schritt 2, Bild 2 von 3 PDP Rematch Advanced Trigger Springs Replacement: Schritt 2, Bild 3 von 3
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
    Frag FixBot
  3. PDP Rematch Advanced Trigger Springs Replacement: Schritt 3, Bild 1 von 2 PDP Rematch Advanced Trigger Springs Replacement: Schritt 3, Bild 2 von 2
    • Twist the thumbstick to remove it from the motherboard.
    Frag FixBot
  4. PDP Rematch Advanced Trigger Springs Replacement: Schritt 4, Bild 1 von 3 PDP Rematch Advanced Trigger Springs Replacement: Schritt 4, Bild 2 von 3 PDP Rematch Advanced Trigger Springs Replacement: Schritt 4, Bild 3 von 3
    • Use a Phillips #000 screwdriver to remove the two 5 mm screws that secure the motherboard.
    • Remove the motherboard from the back shell using moderate force.
    Frag FixBot
  5. PDP Rematch Advanced Trigger Springs Replacement: Schritt 5, Bild 1 von 3 PDP Rematch Advanced Trigger Springs Replacement: Schritt 5, Bild 2 von 3 PDP Rematch Advanced Trigger Springs Replacement: Schritt 5, Bild 3 von 3
    • Punch out the metal pin holding in the trigger and the trigger spring. Repeat for both triggers.
    • Remove the trigger and the trigger springs.
    • Using a punch or a small tool allows pin removal to be easier.
    Frag FixBot
Abschluss
Jacob Thomas Wolgamott
121 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 35
Insgesamt: 550
