Einleitung
If your faceplate is cracked or broken, this guide will help you replace the faceplate for the PDP Rematch controller (model 500-134-1).
The faceplate serves as a protective cover for the controller.
Before beginning, make sure to disconnect the controller's wire from any external power source.
Was du brauchst
Grip one side of the controller firmly.
Insert an opening pick into the crease between the faceplate and the body of the controller.
Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
Carefully move the picks along the controller's crease line until you hear a popping sound.
Gently lift off the faceplate by hand.
Eine weitere Person hat diese Anleitung absolviert.
