Zum Hauptinhalt wechseln
PDP Rematch Top Left and Right Button(s) Replacement
Was du brauchst
  1. PDP Rematch Top Left and Right Button(s) Replacement, Faceplate: Schritt 1, Bild 1 von 2 PDP Rematch Top Left and Right Button(s) Replacement, Faceplate: Schritt 1, Bild 2 von 2
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
    Frag FixBot
    Kommentar hinzufügen
  2. PDP Rematch Top Left and Right Button(s) Replacement: Schritt 2, Bild 1 von 2 PDP Rematch Top Left and Right Button(s) Replacement: Schritt 2, Bild 2 von 2
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
    Frag FixBot
  3. PDP Rematch Top Left and Right Button(s) Replacement: Schritt 3, Bild 1 von 2 PDP Rematch Top Left and Right Button(s) Replacement: Schritt 3, Bild 2 von 2
    • Gently lift off the hard cover with your hand; it should not need much force.
    Frag FixBot
  4. PDP Rematch Top Left and Right Button(s) Replacement, Top Left and Right Buttons: Schritt 4, Bild 1 von 2 PDP Rematch Top Left and Right Button(s) Replacement, Top Left and Right Buttons: Schritt 4, Bild 2 von 2
    • Remove the back panel by pulling it away from the front.
    • Disconnect the cable by squeezing the two sides while pulling the cable away from the motherboard.
    Frag FixBot
  5. PDP Rematch Top Left and Right Button(s) Replacement: Schritt 5, Bild 1 von 2 PDP Rematch Top Left and Right Button(s) Replacement: Schritt 5, Bild 2 von 2
    • Touch the hot tip of the soldering iron to the first solder connecting the buttons to the motherboard until the solder melts.
    • Repeat this for the next solder. Verify solders have detached from motherboard.
    • Be careful of the hot soldering tip.
    Frag FixBot
  6. PDP Rematch Top Left and Right Button(s) Replacement: Schritt 6, Bild 1 von 2 PDP Rematch Top Left and Right Button(s) Replacement: Schritt 6, Bild 2 von 2
    • When the solder has completely melted, flip the controller and gently pull the wire free from the motherboard.
    • Repeat for the other black wire.
    Frag FixBot
Abschluss
GraceGrubbs
147 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 42
Insgesamt: 491
