Zum Hauptinhalt wechseln
PDP Victrix Gambit Prime Wired Tournament Controller Outer Case Replacement
Was du brauchst
  1. PDP Victrix Gambit Prime Wired Tournament Controller Outer Case Replacement, Outer Casing: Schritt 1, Bild 1 von 1
    • Insert an opening tool in the gap between the rear and front case.
    • Pry around the perimeter until the front case releases.
    • Remove the front case.
  2. PDP Victrix Gambit Prime Wired Tournament Controller Outer Case Replacement: Schritt 2, Bild 1 von 1
    • Remove all seven 9 mm Phillips #000 screws securing the midframe.
    • Remove the midframe.
  3. PDP Victrix Gambit Prime Wired Tournament Controller Outer Case Replacement: Schritt 3, Bild 1 von 2 PDP Victrix Gambit Prime Wired Tournament Controller Outer Case Replacement: Schritt 3, Bild 2 von 2
    • Optional: With a pair of tweezers, carefully wipe down the device.
    • It is recommended to use electrical disinfectant wipes or a microfiber towel to clean any excess debris.
Abschluss
After you have thoroughly cleaned the device, follow these steps in reverse order to reassemble the device.
Tessa Baldwin
653 Reputation
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 147
