Use the purple Module Swap Tool that comes with the device to remove the 4 hex screws.
Remove the joystick/button modules from the controller.
Using the iFixit opening tool, gently pry open the two side grips.
Using the screwdriver tool with a head of around 2 mm, remove the screws located in the bottom outside corners.
Flip the controller to the other side so the label on the bottom is facing upwards.
Using the same screwdriver head setting from the previous step, remove the screw.
Flip the controller so the charging port of the controller is facing you.
Using a spudger, carefully pry open the front component.
Flip the controller so it is upside-down, but the charging port is still facing you.
Use the flexible piece attached to the screwdriver to remove this screw.
Now that everything is loosened, gently pry open the controller along the grooves.
Using the screwdriver tool with a smaller head, remove the three screws from each trigger.
Remove the triggers.
Using the screwdriver, remove the two screws in the bottom two corners.
Using the halberd spudger, carefully pry the circuit board open.
Using a soldering iron, desolder the headphone jack and resolder a new one in its place.
