Einleitung
This guide will walk you through replacing your eyewear nose pads.
Was du brauchst
Place a 3-inch strip of tape on the lenses to protect them from being scratched.
Unscrew the nose pad screw using a Phillips-head screw driver. Turn the screw counter-clockwise until the screw can be removed
Place the screw back inside of the nose pad and turn clockwise until the screw is tight. Do not overtighten.
3 weitere Personen haben diese Anleitung absolviert.
