Was du brauchst
remove 2mm screw
remove 3mm screw
remove the three 3.5mm screw
Open the memory protection
Remove gently the rear cover
When re-assembly take care to the thin tabs
This connector is directly to the board
This Flex connector need to be unplug
The 321 battery is there
You can add some thermal glue to fix the battery
I did it with a small piece of scotch
To re-assembly your device follow the step backward
100%
Bertrand PIGEARD hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
