Einleitung
Note::: taking apart your device may void the warranty on the device, please proceed with caution and consider having it sent in first if possible to be worked on by the company. This guide will help you replace the back camera of the PSVita Slim in case anything has gone wrong with the device. This guide should be simple and easy to follow. As long as you take your time and you are careful you should be able to complete the replacement process with ease.
Was du brauchst
All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
There are four screws on the back of the device, remove them as shown.
There are two screws on the bottom, near the charging port, remove them using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
Finally, remove the top screw under the dust cover using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
Upon removing the back panel you will need to slowly and carefully remove the ribbons connecting the hardware to access the needed parts to be repaired.
Once the ribbons have been removed, then the back is fully removed and you can access the hardware within.
So first we must remove the casing, remove the two 6.35 mm screws using a J00 screwdriver.
After the screws have been removed, carefully remove the black casing.
You will need to remove the two 6.35 mm using a J00 screwdriver.
You can now remove the camera, but you must be careful to not damage it.
4 weitere Personen haben diese Anleitung absolviert.
