Einleitung
This guide's goal is to help the user to replace the battery of a PS Vita Slim if the battery is faulty or has some other kind of problem.
Was du brauchst
All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
There are four screws on the back of the device, remove them as shown.
There are two screws on the bottom, near the charging port, remove them using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
Finally, remove the top screw under the dust cover using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
Upon removing the back panel you will need to slowly and carefully remove the ribbons connecting the hardware to access the needed parts to be repaired.
Once the ribbons have been removed, then the back is fully removed and you can access the hardware within.
Using the spudger, carefully pry the battery connector upwards out of the socket. Do not fully remove the battery yet.
Now using the tweezers, carefully remove the ribbon connecting the battery from the hardware.
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Whilst tearing down my PCH-2016 model PS Vita Slim I have noticed that there is also a screw in the cartridge area that needs to be removed to remove the back panel.
