Einleitung
Use this guide to replace the joystick covers on your controller.
Was du brauchst
Remove the two 10 mm Phillips #1 screws that secure each of the handle grips.
Pull off the handle grips.
Remove the four 9 mm Phillips #1 screws that secure the rear case.
Lift off the rear case from the controller.
Use blunt tweezers to pull the white battery motherboard connector directly out of its port.
Gently peel the battery off of the motherboard.
Remove the two 7 mm Phillips #1 screws that secure the motherboard.
Flip up the black ZIF locking flap that secures the touchpad ribbon cable on the top-right edge of the motherboard.
Use tweezers or your fingers to gently disconnect the touchpad ribbon cable.
Lift the motherboard up and out.
Eine weitere Person hat diese Anleitung absolviert.
