Zum Hauptinhalt wechseln
PSKONTORORA LBER-P4-05 Vibration Motor Replacement
Was du brauchst
  1. PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Rear Case: Schritt 1, Bild 1 von 3 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Rear Case: Schritt 1, Bild 2 von 3 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • Remove the two 10 mm Phillips #1 screws that secure each of the handle grips.
    • Pull off the handle grips.
    Frag FixBot
    Kommentar hinzufügen
  2. PSKONTORORA LBER-P4-05 Vibration Motor Replacement: Schritt 2, Bild 1 von 3 PSKONTORORA LBER-P4-05 Vibration Motor Replacement: Schritt 2, Bild 2 von 3 PSKONTORORA LBER-P4-05 Vibration Motor Replacement: Schritt 2, Bild 3 von 3
    • Remove the four 9 mm Phillips #1 screws that secure the rear case.
    • Lift off the rear case from the controller.
    Frag FixBot
  3. PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Battery: Schritt 3, Bild 1 von 3 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Battery: Schritt 3, Bild 2 von 3 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Battery: Schritt 3, Bild 3 von 3
    • Use blunt tweezers to pull the white battery motherboard connector directly out of its port.
    • Gently peel the battery off of the motherboard.
    • Be sure not to bend or puncture the battery during removal.
    Frag FixBot
  4. PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Joystick Covers: Schritt 4, Bild 1 von 1
    • Remove the two 7 mm Phillips #1 screws that secure the motherboard.
    Frag FixBot
  5. PSKONTORORA LBER-P4-05 Vibration Motor Replacement: Schritt 5, Bild 1 von 2 PSKONTORORA LBER-P4-05 Vibration Motor Replacement: Schritt 5, Bild 2 von 2
    • Flip up the black ZIF locking flap that secures the touchpad ribbon cable on the top-right edge of the motherboard.
    • Use tweezers or your fingers to gently disconnect the touchpad ribbon cable.
    • Lift the motherboard up and out.
    Frag FixBot
  6. PSKONTORORA LBER-P4-05 Vibration Motor Replacement: Schritt 6, Bild 1 von 2 PSKONTORORA LBER-P4-05 Vibration Motor Replacement: Schritt 6, Bild 2 von 2
    • Use your fingers to pull the joystick covers directly up and off the modules.
    • Clean or replace the joystick covers as necessary.
    Frag FixBot
  7. PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Vibration Motor: Schritt 7, Bild 1 von 3 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Vibration Motor: Schritt 7, Bild 2 von 3 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Vibration Motor: Schritt 7, Bild 3 von 3
    • Prop the motherboard up with a non-flammable material.
    • Carefully desolder each of the vibration motor motherboard connections.
    • Take note of which wires belong where.
    • Be sure to solder in a well-ventilated area and take appropriate safety precautions.
    • Remove the vibration motors.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 30
Insgesamt: 458
