1. That's my PSP. As you can see, the UMD door it's broken. It fell down when I was playing. That's the part where the screws are located. You must move away the battery before doing nothing. We must unscrew the screws marked with colour blue.
    • That's my PSP. As you can see, the UMD door it's broken. It fell down when I was playing.
    • That's the part where the screws are located. You must move away the battery before doing nothing.
    • We must unscrew the screws marked with colour blue.
    • Remind to keep safe the screws, because you can loose them!
  2. After unscrew the screws we can move away the front case.
    • After unscrew the screws we can move away the front case.
    • This is the button board. In my case it's damaged.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. This is one of the two clips which the button board has. With an oppener tool you should release it. Be careful with this ribbon cabble! Be careful with this ribbon cabble!
    • This is one of the two clips which the button board has. With an oppener tool you should release it.
    • Be careful with this ribbon cabble!
  5. Lift the latch open, away from the ribbon cable. Pull the cable away from the latch, and we are done! Be careful with the latch because it brakes easily!
    • Lift the latch open, away from the ribbon cable.
    • Pull the cable away from the latch, and we are done! Be careful with the latch because it brakes easily!
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Javi
227 Reputation
1 Anleitung geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,222
