Einleitung
This guide will show you how to remove and replace your PSP speakers.
Was du brauchst
Locate the battery casing button on the rear-left side of the PSP.
Press down the button and remove the battery cover.
Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
Remove screws from back righthand side within the holes.
The Button Board, at the base of the LCD Screen, is held by two clips.
Pry these clips over the nubs using a PSP opening tool. This will release the clips.
The Button Board Ribbon Cable is held down with a latch. Lift the latch open, away from the ribbon cable.
Pull the cable away from the latch.
The LCD Screen is held by the LCD Frame with similar clips. Slide a thin tool between the clip and the screen and gently pry them apart while beginning to lift the screen.
The LCD screen is still attached with ribbon cables. Gently lift up the LCD screen so you do not break them.
The thin Ribbon Cable opens from the opposite side in which the Ribbon Cable enters. Open up the latch towards the Ribbon Cable. The latch will pull up and release the ribbon cable. Put your tool behind the black part, then pry up the black piece of plastic.
The wide Ribbon Cable opens from the same side in which the Ribbon Cable attatches, and opens away from the cable.
Both of these latches are the black pieces.
Gently pull the ribbon cables away from the latches. The LCD screen can now be removed.
Remove the screws on the top and bottom of the frame. Be sure to keep track of where you took each screw out of.
After the screws are removed, the bottom of the LCD frame will rise.
Open up the UMD Drive, and then slide the top of the LCD frame slightly to the right while pulling out.
The speakers should slide out fairly easily; it may be helpful to use tweezers to begin prying them out.
Gently unplug the speakers from the socket. The speakers are completely detatched when they are unplugged from the logic board.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
