Einleitung
Hate it when you can't get it up? We mean buttons, of course... fix them with our quick and easy steps.
Was du brauchst
Place PSP face down, so that the UMD Drive is facing upwards.
Locate the battery door and open.
Remove the battery from inside.
Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
Remove the sticker using the PSP Opening Tools.
Remove the following screws from around the bezel:
Two 4 mm Phillips
One 5 mm Phillips
Gently pry the front bezel away from the casing using a PSP opening tool.
Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
With the PSP's faceplate removed, position the PSP so that the analogue stick is easily attainable.
Gently pull up on the analogue stick. It should just pop off from the rest of the device.
In order to clean it correctly, take a cotton swab w/ rubbing alcohol and clean the base of the analogue stick.
The connection point on the PSP should be done as well (where the analogue stick meets the PSP).
Next, with the faceplate turned upside down, locate the clear/white rubber backing of the D-pad to the left of the display window.
Gently peel back and proceed to remove the directional buttons from the faceplate.
Now is the time to clean the rubber backing and D-pad with rubbing alcohol, being sure to remove as much dirt and dust as possible.
This process can also be done to the Action Keys (x, square, triangle, circle).
Locate the black rubber backing on the right of the display window and gently remove.
Again take a clean cotton swab with rubbing alcohol and clean away all dirt at dust.
28 weitere Personen haben diese Anleitung absolviert.
5 Kommentare
I found <a href=http://www.buyincoins.com>a nice site, where can buy good products, buyincoins</a>- a professional electronics online website, <a href=http://www.buyincoins.com>what let you buy from China directly </a>without any shipping fee. There are Computer Accessories, iPod, iPhone Accessories, HDMI Video Cable, Laser Pointer, Card Reader, Headphone, Silicone Case and more Cool Gadgets.
I found <a href=http://www.buyincoins.com>a nice site, where can buy good products, buyincoins</a>- a professional electronics online website, <a href=http://www.buyincoins.com>what let you buy from China directly </a>without any shipping fee. There are Computer Accessories, iPod, iPhone Accessories, HDMI Video Cable, LaserPointer, Card Reader, Headphone, Silicone Case and more Cool Gadgets.
