Zum Hauptinhalt wechseln
PSP E1000 LED Driver Circuit Component Replacement
Was du brauchst
  1. PSP E1000 LED Driver Circuit Component Replacement, Backlight electronic after water damage: Schritt 1, Bild 1 von 1
    • this picture was made after cleaning
  2. PSP E1000 LED Driver Circuit Component Replacement: Schritt 2, Bild 1 von 2 PSP E1000 LED Driver Circuit Component Replacement: Schritt 2, Bild 2 von 2
    • it took me some time to find the right chip:
    • 1 - TB62752AFUG
    • 2 - Inductor 22µH/0.66A
    • 3 - MSS1P4-M3/89A
    • 4 - 2.2µF / 6,3V
    • 5 - Fuse 0.5A 0603
    • 6 - 1.0µF / 50V
    • 7 - Ferrite bead 30Ohm/3A
Ziellinie
11 weitere Nutzer:innen haben diese Anleitung absolviert.
Steven
416 Reputation
1 Anleitung geschrieben
7 Kommentare
Hi Steven,
Thank for your guide. It helped me restore my PSP street (in my case, the fuse was broken). But one more problem is my PSP street has no sound on speaker, but has sound on headphone. Can you give me a glue to fix?
Thank you.
Hoang Binh - Antwort
I fixed it! There a broken fuse near the audio ic. Hooray!!!
Hoang Binh -
Hello Hoang Binh, I have the same problem as you, after changing the fuse to illuminate the display, no sound is heard through the speaker (only when connecting headphones, through them). Can you tell me, please, which is the fuse has been changed to solve the sound problem? An image whit the fuse be very helpful.
Olivian -
Hi @olivian. Sorry for late reply. I didn’t take any picture so I cannot point it out exactly. But you can find it yourself. Fuses often have a letter F or FB on it or its color is blue.
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 33
Letzte 30 Tage: 165
Insgesamt: 9,391
