Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Use this guide to replace your PSP Go's top cover.
  1. Unscrew the four Phillips screws on the back of the PSP Go. Rotate the PSP so you can see the top of the device.
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
  2. Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides. Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
  3. Pull the top cover upwards gently from its housing.
    • Pull the top cover upwards gently from its housing.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 9
Insgesamt: 5,440
