Einleitung
The only tool required for lens removal is a JIS (J0) screwdriver bit. Replacing the lens will enable you to continue scanning images onto a computer.
Was du brauchst
Use the J0 screwdriver to remove the 5 following screws that are 9 mm x 7 mm.
Abschluss
