Einleitung
This guide will show you have to remove the viewing screen from the front of the scanner if the screen breaks, or is no longer transparent.
Was du brauchst
To start, open the device by removing the 5, 5mm x 9mm screws, with a J1 screwdriver.
Push the screen away from the scanner from the inside with light force until it is no longer attached.
Replace with a new screen.
Abschluss
