Was du brauchst
Remove the battery.
Unscrew the red marked screws with a Phillips screwdriver.
Remove the DVD reader.
Pry in the red marked spots to release the keyboard
Unplug the keyboard connector.
Unplug the 3 connectors on the motherboard
Remove the 2 screws holding the display in place
Use a thin tool to pry up the back cover of the laptop on the side
Remove the back cover.
Remove the HDD.
Remove the screws that hold the motherboard.
Remove the marked screws and connectors.
Disconnect the display connector.
Remove the display.
Remove the cooling fan.
Remove the heatsink.
Remove the screws on the connector.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
100%
Hier starten ›
