Einleitung
Follow this guide if you need to replace the back case of your Palm Centro or if you need to access the internals of your device.
Was du brauchst
Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
Lift the rubber cap at the top right to reveal the sixth screw.
Remove the six screws using the T5 Torx screwdriver.
Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
Continue with plastic pry tool all the way around the phone to remove the back housing.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
