Zum Hauptinhalt wechseln
Palm Centro Screen Replacement
Was du brauchst
  1. Palm Centro Screen Replacement, Disassembling Palm Centro Battery: Schritt 1, Bild 1 von 2 Palm Centro Screen Replacement, Disassembling Palm Centro Battery: Schritt 1, Bild 2 von 2
    • Press and slide open the battery cover.
  2. Palm Centro Screen Replacement: Schritt 2, Bild 1 von 1
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Palm Centro Screen Replacement: Schritt 3, Bild 1 von 1
    • Phone with battery removed
  4. Palm Centro Screen Replacement, Back Housing: Schritt 4, Bild 1 von 1
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Palm Centro Screen Replacement: Schritt 5, Bild 1 von 1
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Palm Centro Screen Replacement: Schritt 6, Bild 1 von 2 Palm Centro Screen Replacement: Schritt 6, Bild 2 von 2
    • Remove the SIM card so housing can be separated.
  7. Palm Centro Screen Replacement: Schritt 7, Bild 1 von 2 Palm Centro Screen Replacement: Schritt 7, Bild 2 von 2
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Palm Centro Screen Replacement: Schritt 8, Bild 1 von 2 Palm Centro Screen Replacement: Schritt 8, Bild 2 von 2
    • Remove the small plastic insert at the bottom of the phone.
  9. Palm Centro Screen Replacement: Schritt 9, Bild 1 von 2 Palm Centro Screen Replacement: Schritt 9, Bild 2 von 2
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
  10. Palm Centro Screen Replacement, Logic Board: Schritt 10, Bild 1 von 1
    • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
  11. Palm Centro Screen Replacement: Schritt 11, Bild 1 von 1
    • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Be very careful, these electronics are delicate!
  12. Palm Centro Screen Replacement: Schritt 12, Bild 1 von 1
    • Separate the logic board from the case by lifting and pulling out the bottom.
  13. Palm Centro Screen Replacement, Screen: Schritt 13, Bild 1 von 1
    • Slowly peel off the protective lining that is on the screen and keyboard.
  14. Palm Centro Screen Replacement: Schritt 14, Bild 1 von 2 Palm Centro Screen Replacement: Schritt 14, Bild 2 von 2
    • Lift and slowly remove the screen from the front panel
    • Place the new screen into the front panel
    • Make sure the new screen goes in under the plastic tabs for the additional memory slot door or it may not close properly once the phone is put back together.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Tony
10 Reputation
1 Anleitung geschrieben
Cal Poly, Team 15-49, Garner Spring 2010 Mitglied von Cal Poly, Team 15-49, Garner Spring 2010
CPSU-GARNER-S10S15G49
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 2,959
