Zum Hauptinhalt wechseln
Palm Centro Speakers Replacement
Was du brauchst
  1. Palm Centro Speakers Replacement, Disassembling Palm Centro Battery: Schritt 1, Bild 1 von 2 Palm Centro Speakers Replacement, Disassembling Palm Centro Battery: Schritt 1, Bild 2 von 2
    • Press and slide open the battery cover.
  2. Palm Centro Speakers Replacement: Schritt 2, Bild 1 von 1
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Palm Centro Speakers Replacement: Schritt 3, Bild 1 von 1
    • Phone with battery removed
  4. Palm Centro Speakers Replacement, Back Housing: Schritt 4, Bild 1 von 1
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Palm Centro Speakers Replacement: Schritt 5, Bild 1 von 1
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Palm Centro Speakers Replacement: Schritt 6, Bild 1 von 2 Palm Centro Speakers Replacement: Schritt 6, Bild 2 von 2
    • Remove the SIM card so housing can be separated.
  7. Palm Centro Speakers Replacement: Schritt 7, Bild 1 von 2 Palm Centro Speakers Replacement: Schritt 7, Bild 2 von 2
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Palm Centro Speakers Replacement: Schritt 8, Bild 1 von 2 Palm Centro Speakers Replacement: Schritt 8, Bild 2 von 2
    • Remove the small plastic insert at the bottom of the phone.
  9. Palm Centro Speakers Replacement: Schritt 9, Bild 1 von 2 Palm Centro Speakers Replacement: Schritt 9, Bild 2 von 2
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
  10. Palm Centro Speakers Replacement, Logic Board: Schritt 10, Bild 1 von 1
    • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
  11. Palm Centro Speakers Replacement: Schritt 11, Bild 1 von 1
    • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Be very careful, these electronics are delicate!
  12. Palm Centro Speakers Replacement: Schritt 12, Bild 1 von 1
    • Separate the logic board from the case by lifting and pulling out the bottom.
  13. Palm Centro Speakers Replacement, Speakers: Schritt 13, Bild 1 von 3 Palm Centro Speakers Replacement, Speakers: Schritt 13, Bild 2 von 3 Palm Centro Speakers Replacement, Speakers: Schritt 13, Bild 3 von 3
    • Pry the four plastic latches free that connect the antenna to the logic board.
    • Excessive force may damage your logic board!
    • Remove the antenna from the logic board.
  14. Palm Centro Speakers Replacement: Schritt 14, Bild 1 von 1
    • The internal speaker is attached to the antenna. To remove it, pry the speaker from the antenna using the tip of your screwdriver.
    • The speaker should be placed back into its spot in the correct position. Take notice of the gold connectors
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Kevin
31 Reputation
1 Anleitung geschrieben
Cal Poly, Team 15-49, Garner Spring 2010 Mitglied von Cal Poly, Team 15-49, Garner Spring 2010
CPSU-GARNER-S10S15G49
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 1,573
