Zum Hauptinhalt wechseln
Einleitung
A guide to replace a damaged, lost, or broken button cluster.
  1. Place the Palm IIIx face down on a flat surface.
    • Place the Palm IIIx face down on a flat surface.
  2. Push down, lift up on, and remove battery cover.
    • Push down, lift up on, and remove battery cover.
  3. Remove the old batteries one at a time.
    • Remove the old batteries one at a time.
  4. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  5. Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
    • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  6. Hold the device on its side, positioning your hands as shown.
    • Hold the device on its side, positioning your hands as shown.
    • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers
  7. Hold the screen and front cover in a vertical position, facing the screen inward, as shown.
    • Hold the screen and front cover in a vertical position, facing the screen inward, as shown.
    • Position your hands so you can push the screen outward with your thumbs.
    • Remove the front cover by gently pushing outward with your thumbs. Use your index fingers to pull back on the front cover.
  8. Remove cluster by pulling on the rubber backing.
    • Remove cluster by pulling on the rubber backing.
    • Clean, repair, and/or replace as neccessary.
Abschluss
David Haskell
44 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 14-43, Regan Winter 2010 Mitglied von Cal Poly, Team 14-43, Regan Winter 2010
CPSU-REGAN-W10S14G43
4 Mitglieder
4 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,197
