Einleitung
The screen protects the camera from external damage, but in doing so can itself become damaged. This can be remedied by removing the screen and putting in a new one.
Was du brauchst
Push in the button at the bottom of the phone, and lift the back cap off.
Using the 1.5mm hex screwdriver, remove the 6 hex screws from the inner-most casing.
While applying pressure, use your tweezers to remove the screen from the inner casing.
