Zum Hauptinhalt wechseln
Palm Pre 2 Motherboard Replacement
Was du brauchst
  1. Palm Pre 2 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 2 Palm Pre 2 Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Make sure your Palm Pre 2 is turned off before taking apart the phone.
    • Snap off the back panel to reveal the battery using the opening tool.
  2. Palm Pre 2 Motherboard Replacement: Schritt 2, Bild 1 von 3 Palm Pre 2 Motherboard Replacement: Schritt 2, Bild 2 von 3 Palm Pre 2 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Pull on the tab to remove the battery.
  3. Palm Pre 2 Motherboard Replacement: Schritt 3, Bild 1 von 2 Palm Pre 2 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Use the T5 Torx Screwdriver to remove the six screws that hold the back of the frame in place.
  4. Palm Pre 2 Motherboard Replacement: Schritt 4, Bild 1 von 2 Palm Pre 2 Motherboard Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a spudger to open the hinge that covers the black and white GPS and DIV antennas (Reference the red box in the image).
    • Use tweezers to remove the two antennas from the keypad control board.
  5. Palm Pre 2 Motherboard Replacement: Schritt 5, Bild 1 von 2 Palm Pre 2 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Use the opening tool to pry off the (black and yellow) back frame.
  6. Palm Pre 2 Motherboard Replacement: Schritt 6, Bild 1 von 3 Palm Pre 2 Motherboard Replacement: Schritt 6, Bild 2 von 3 Palm Pre 2 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Use the opening tool to remove the panel on the main part of the phone.
    • Use the tweezers to get access to remove the panel giving access to the cable connectors.
    • Remove the two ribbon cable connectors using the tweezers.
  7. Palm Pre 2 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Use tweezers to separate the keyboard from the phone.
  8. Palm Pre 2 Motherboard Replacement: Schritt 8, Bild 1 von 2 Palm Pre 2 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the remaining 4 screws from the main portion of the phone.
    • Use an opening tool to remove the motherboard.
Abschluss
Cole Simmerman
160 Reputation
1 Anleitung geschrieben
IUPUI, Team S1-G6, Freund Spring 2018 Mitglied von IUPUI, Team S1-G6, Freund Spring 2018
IUPUI-FREUND-S18S1G6
2 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 275
