Zum Hauptinhalt wechseln
Palm Pre Antenna Replacement
Was du brauchst
  1. Palm Pre Antenna Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure your Palm Pre is turned off before disassembling the phone.
    • Snap off the back panel to reveal the battery.
  2. Palm Pre Antenna Replacement: Schritt 2, Bild 1 von 1
    • Carefully pull up on the tab to remove the current battery.
  3. Palm Pre Antenna Replacement, Antenna: Schritt 3, Bild 1 von 2 Palm Pre Antenna Replacement, Antenna: Schritt 3, Bild 2 von 2
    • Use the T5 Torx Screwdriver to remove the six screws holding the backing frame in place.
  4. Palm Pre Antenna Replacement: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Locate the hinge that covers the black and white GPS and DIV antennas. (The hinge will be located in the red box as portrayed in the picture.)
    • Use a spudger to pry open the hinge.
    • Use tweezers to disconnect the antennas from the keypad control board.
  5. Palm Pre Antenna Replacement: Schritt 5, Bild 1 von 2 Palm Pre Antenna Replacement: Schritt 5, Bild 2 von 2
    • Use a spudger to pry off the (black and yellow) back frame.
    • Disregard the main part of the phone at this point and look only at the inside of the removed back frame. (You will need the main part of the phone for access to the keyboard and motherboard)
  6. Palm Pre Antenna Replacement: Schritt 6, Bild 1 von 1
    • Find the small circuit board at the top right and desolder the wires that are connected to it.
    • This step is only necessary for antenna removal.
Abschluss
noha
139 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 7-31, Maness Spring 2012 Mitglied von Cal Poly, Team 7-31, Maness Spring 2012
CPSU-MANESS-S12S7G31
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,317
