Was du brauchst
Make sure your Palm Pre is turned off before disassembling the phone.
Snap off the back panel to reveal the battery.
Use the T5 Torx Screwdriver to remove the six screws holding the backing frame in place.
Locate the hinge that covers the black and white GPS and DIV antennas. (The hinge will be located in the red box as portrayed in the picture.)
Use a spudger to pry open the hinge.
Use tweezers to disconnect the antennas from the keypad control board.
Find the small circuit board at the top right and desolder the wires that are connected to it.
Remove the two ribbon cable connectors using tweezers.
Slide the keyboard away from the phone.
Lift up slightly on the backing plate.
Do not tear the ribbon cables when removing the backing plate. Instead use tweezers to remove them.
Eine weitere Person hat diese Anleitung absolviert.
