Zum Hauptinhalt wechseln
Palm Pre PCB (Phone Circuit Board) Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Palm Pre PCB (Phone Circuit Board) Replacement, Antenna: Schritt 1, Bild 1 von 2 Palm Pre PCB (Phone Circuit Board) Replacement, Antenna: Schritt 1, Bild 2 von 2
    • First the back panel must be removed to reveal the battery.
    • Remove the battery pack.
  2. Palm Pre PCB (Phone Circuit Board) Replacement: Schritt 2, Bild 1 von 2 Palm Pre PCB (Phone Circuit Board) Replacement: Schritt 2, Bild 2 von 2
    • Remove the six T5 screws necessary to separate the backplate from the phone.
    • There is one screw in the upper right that is concealed by a small sticker labeled "Palm."
    • Additionally, there are interlocking tabs securing the back plate around the edges.
    • Use the opening tool to carefully go around the phone releasing these tabs.
  3. Palm Pre PCB (Phone Circuit Board) Replacement: Schritt 3, Bild 1 von 2 Palm Pre PCB (Phone Circuit Board) Replacement: Schritt 3, Bild 2 von 2
    • Lift the metal flap marked in red to reveal the antenna connectors.
    • Carefully pry these the antennas from their connections, this can be done quite easily.
    • Take note of which colored wire is attached to each connection. The white wire corresponds to GPS, while the black wire corresponds to DIV, or diversity antenna.
  4. Palm Pre PCB (Phone Circuit Board) Replacement, PCB (Phone Circuit Board): Schritt 4, Bild 1 von 3 Palm Pre PCB (Phone Circuit Board) Replacement, PCB (Phone Circuit Board): Schritt 4, Bild 2 von 3 Palm Pre PCB (Phone Circuit Board) Replacement, PCB (Phone Circuit Board): Schritt 4, Bild 3 von 3
    • With the backplate removed, we have easy access to the PCB.
    • Two connectors must be disconnected so that we can remove the PCB.
    • Gentle prying with the opening tool should easily separate the glued PCB from the rest of the phone.
Abschluss
iDeleted
2.101 Reputation
39 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 418
