Was du brauchst
Make sure your Palm Pre is turned off before disassembling the phone.
Snap off the back panel to reveal the battery.
Use the spudger to locate the crease at the bottom of the keyboard.
Carefully work your way around the phone separating the back frame from the keyboard.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers to remove the DIV and GPS antennas from the back of the keyboard.
Use the spuger to pry out the speaker. It is magnetically connected so do not be afraid to use the necessary force.
Make sure not the puncture the screen on the outside of the back frame.
