Einleitung
Removing the back panel allows you to access the various parts of the Palm T|X PDA.
Was du brauchst
Orient the device so that the display faces forward.
Remove the stylus from the right side.
Turn over the device so that the back panel faces forward.
Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
Rotate the device so that the display faces forward.
Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
Pry along the crevice to loosen the back panel.
Repeat this process for the right side.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
