Einleitung
Follow this guide if the battery is dysfunctional and you want to replace it.
Was du brauchst
On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
Slide the flat side of the spudger under the battery and gently dislodge the battery by lifting the spudger up.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
