Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Follow this guide if the battery is dysfunctional and you want to replace it.
Ersatzteile
Keine Ersatzteile angegeben.
  1. On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Use the T6 Torx Screwdriver to remove all 4 screws. You have to first remove the Stylus to  access the 4th screw.
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  4. Using a plastic opening tool, carefully separate the front and back cases. Note: The antenna will detach from the phone.
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  5. Using metal tweezers, unplug small white plug. Pulling the white plug will disconnect the battery. Make sure the phone is off before you do this step.
    • Using metal tweezers, unplug small white plug.
    • Pulling the white plug will disconnect the battery. Make sure the phone is off before you do this step.
  6. Slide the flat side of the spudger under the battery and gently dislodge the battery by lifting the spudger up.
    • Slide the flat side of the spudger under the battery and gently dislodge the battery by lifting the spudger up.
    • The battery may be glued to the phone.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Clement Poisson
24 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 13-23, Maness Winter 2010 Mitglied von Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Mitglieder
16 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 12
Insgesamt: 5,129
