Einleitung
If your camera doesn't work and it needs to be replaced, this guide will come in handy.
Was du brauchst
On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
Using the flat end of the spudger, lift the metal case off of the camera.
Slide the flat end of the spudger between the printed circuit board and metal holder.
Pop the camera up
