Zum Hauptinhalt wechseln
Einleitung
If your camera doesn't work and it needs to be replaced, this guide will come in handy.
  1. On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Use the T6 Torx Screwdriver to remove all 4 screws. You have to first remove the Stylus to  access the 4th screw.
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Using a plastic opening tool, carefully separate the front and back cases. Note: The antenna will detach from the phone.
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  5. Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
    • Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
  6. Lift up the silver casing.
    • Lift up the silver casing.
    • Careful! The casing is connected to the body. Pull the casing up.
  7. With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
    • With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
  8. Use the spudger to lift the logic board from its socket.  Remove it from the rest of the phone. Use the spudger to lift the logic board from its socket.  Remove it from the rest of the phone.
    • Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
  9. Using the flat end of the spudger, lift the metal case off of the camera. Using the flat end of the spudger, lift the metal case off of the camera.
    • Using the flat end of the spudger, lift the metal case off of the camera.
  10. Slide the flat end of the spudger between the printed circuit board and metal holder. Pop the camera up Pop the camera up
    • Slide the flat end of the spudger between the printed circuit board and metal holder.
    • Pop the camera up
Abschluss
Clement Poisson
24 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 13-23, Maness Winter 2010 Mitglied von Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Mitglieder
16 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
Insgesamt: 1,489
