Zum Hauptinhalt wechseln
Einleitung
Replace the keyboard!!
Ersatzteile
Keine Ersatzteile angegeben.
  1. On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Use the T6 Torx Screwdriver to remove all 4 screws. You have to first remove the Stylus to  access the 4th screw.
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Using a plastic opening tool, carefully separate the front and back cases. Note: The antenna will detach from the phone.
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Using a T6 Torx Screwdriver, remove the two screws. The motherboard will now be loose from the front case.
    • Using a T6 Torx Screwdriver, remove the two screws.
    • The motherboard will now be loose from the front case.
  5. Using the spudger, flip open the clasp that holds the data ribbon in place.
    • Using the spudger, flip open the clasp that holds the data ribbon in place.
  6. Pull out the ribbon.
    • Pull out the ribbon.
    • The keyboard will disconnect from the phone.
Abschluss
Clement Poisson
24 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 13-23, Maness Winter 2010 Mitglied von Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Mitglieder
16 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,422
